qt_dragon_hd - manual tool change and remap
3 years 5 months ago #272405 by cmorley
depending on how old of a version you have there is a label on the probe screen 'motion type'
It will say 'probe' when linuxcnc is expecting a probe signal.
You can also load a similar temporary display panel by adding to the INI:
Just don't try to use the button on that panel as you have already connected the motion.probe-in pin to something else, but it will display the motion type.
[HAL] POSTGUI_HALCMD = loadusr qtvcp test_probe
3 years 5 months ago - 3 years 5 months ago #272534 by grey_goat
This is really weird. I don't believe I changed anything besides adding that [HAL]
POSTGUI_HALCMD = loadusr qtvcp test_probe into the INI file.
Now I no longer get movement to the toolsetter position or movement in the negative z direction where the tool setter is supposed to sit. Instead I get, "Auto Tool probe disabled," and the machine ceases to move.
Just as a side note, when I press the probe the green light in the probe window lights up.  Also, the version of LinuxCNC I'm using is 2.9.0~pre1.787.g913733ff1
Last edit: 3 years 5 months ago by grey_goat.
3 years 5 months ago #272559 by cmorley
goto the versa probe screen and make sure the ;tool measure' button is checked.
3 years 5 months ago #272607 by grey_goat
Thank you.
When heading towards the toolsetter in the negative z the motion type is, "feed."
3 years 5 months ago #272612 by cmorley
Feed is right. All the probe moves use feed (g1) so it aborts if the probe trips.
3 years 5 months ago #272613 by grey_goat
So any suggestions why I'm getting,
"Probe tripped during non-probe move. Error Parameter is [3.000000}."
Time to create page: 0.267 seconds
