Homemade, cheap, plasma CNC
4 years 11 months ago #227153 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
That is why I find it easier if it is all on one line, that way you know it is all in one place.
But my one line didn't make it to his hal file. I nearly did it on two lines but I was lazy and did it Phil's way :)
I think its easier for novices to understand on two lines.
4 years 11 months ago #227154 by phillc54
Probably because the same net is in both hal files...
4 years 11 months ago - 4 years 11 months ago #227157 by phillc54
If this is for a laser then I would suggest:
comment these four lines out in PLASMA.ini file:
BUTTON_10_NAME = ZERO ON\LASER BUTTON_10_CODE = G91 G54 G1 X-49.15 Y-8.35 F1500 \ G90 \ G10 L20 BUTTON_11_NAME = LASER BUTTON_11_CODE = toggle-halpin laser-switch
delete this line in custom.hal:
net plasmac:laser-switch =>  hm2_7i96.0.ssr.00.out-01
add this line in PLASMA.hal from:
net plasmac:laser-switch  <= qtplasmac.laser_on
after starting linuxcnc go to the parameters tab and set the offsets for the laser, then the laser button will appear in the dro frame.
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_laser
linuxcnc.org/docs/devel/html/plasma/qtpl...l#peripheral-offsets
Last edit: 4 years 11 months ago by phillc54.
4 years 11 months ago - 4 years 11 months ago #227158 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Thanks Phil & Rod,
Total newb error I'm sure.
I have made the changes.
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:laser-switch     <= plasmac.laser-on
# external output signals
# --- LASER ---
I now get the following error.
"PLASMA.hal:58: Pin plasmac.laser-on does not exist"
Last edit: 4 years 11 months ago by RNJFAB.
4 years 11 months ago #227159 by rodw
Needs to be in postgui file because the pin is created in the gui.
4 years 11 months ago - 4 years 11 months ago #227160 by RNJFAB
If i put that line in the postgui file i get the same error.
This laser is a sighting laser. Just so i can see where i'm going to be cutting. NOT A CUTTING LASER. it is run from a relay activated by the MESA7i96 through one of its outputs.
Time to create page: 0.502 seconds
