Homemade, cheap, plasma CNC
4 years 11 months ago - 4 years 11 months ago #227169 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
Expected use is to use the laser button  at bottom right. I would try that first.
Then follow Phil's instructions if you want to use a button
Last edit: 4 years 11 months ago by rodw.
4 years 11 months ago #227171 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Hey Phil,
No doubt in the future I will. For now I'm still getting my head around the basic running of things.
I still need to setup all the tools from sheetcam (i don't know if i can just import them, currently just creating each tool as i go), and then I'll need to change the PP in sheetcam so as not to add tool details, and then I'll try and workout how to do spotting.
I have read about all these things but I'm not at the same level as the rest of you, in fact i may very well still be in the basement trying to find the light.
Thank you for all the help. I'll continue to read.
4 years 11 months ago #227173 by rodw
That is super easy thanks to Phil. From Sheetcam, save your toolset (in windows or linuxcnc), get it on your lcnc machine and type
[code]qtplasmac-materials
[/code]
and follow your nose.
Ref:  linuxcnc.org/docs/devel/html/plasma/qtpl...#_material_converter
There is a plasmac postprocessor on the windows version so use that. Move it to your linux machine too.
You may need to edit it to change a setting. If I get a chance, I'll email you the latest during the week.
AND don't worry about your skill set. We all knew nothing about Linuxcnc once!
4 years 11 months ago #227174 by phillc54
+1
4 years 11 months ago #227192 by bevins
Replied by bevins on topic Homemade, cheap, plasma CNC
[code] week. AND don't worry about your skill set. We all knew nothing about Linuxcnc once!
[/code]
That's not true. It is rumored that Tommy was born with the linuxcnc gene's.
The following user(s) said Thank You: phillc54, tommylight, rodw
4 years 11 months ago - 4 years 11 months ago #227193 by tommylight
Took some time to stop laughing ! :)
Last edit: 4 years 11 months ago by tommylight.
Time to create page: 0.264 seconds
