12 Feb 2025 20:20 #321378 by beauxnez
Thank you for your patience, still error
Debug file information:
Note: Using POSIX realtime
MOTION: num_joints is 33, must be between 1 and 16
motmod: rtapi_app_main: Operation not permitted (-1)
./NVEM.hal:5: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:5: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:5: insmod for motmod failed, returned -1
10762
Stopping realtime threads
Unloading hal components
  • Moderator
  • Moderator
12 Feb 2025 21:31 #321383 by tommylight
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
33 ?
Should probably be 3 for normal machines.
The following user(s) said Thank You: cakeslob
13 Feb 2025 18:56 #321459 by LeslieTroyer
Replied by LeslieTroyer on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Im confused --
RPI5 - linuxcnc 2.9.2 (from iso on linuxcnc download page)  I get same results on linux on a x86 system
I have a Novusun V5 that I loaded with ....Remora-RT1052-cpp/blob/main/Firmware/remora-rt1052-3.1.3.bin
I've run halcompile on remora-nv in Remora-NVEM-main/LinuxCNC/Components/Remora-nv
i can ping 10.10.10.10
I can tfpt put the python processed config.txt ...  I cant load tftpy for some reason so save & use the file created in /tmp
using the remora-nvem-basic when I take it out of E-Stop I get
Bad payload = 0
any suggestions
thanks
Les
13 Feb 2025 18:58 - 13 Feb 2025 19:06 #321461 by beauxnez
I deleted xhc-whb04b-6.hal still an error
I no longer have the problem of " MOTION: num_joints is 33, must be between 1 and 16"
I post you the .ini and .hal files in
File Name: NVEM_2025-02-13.hal
File Size:4 KB
File Name: NVEM_2025-02-13.ini
File Size:3 KB
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/manu/linuxcnc/configs/NVEM'
Machine configuration file is 'NVEM.ini'
INIFILE=/home/manu/linuxcnc/configs/NVEM/NVEM.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtplasmac
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./NVEM.hal
motmod: already exists
./NVEM.hal:6: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:6: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:6: insmod for motmod failed, returned -1
8403
Last edit: 13 Feb 2025 19:06 by beauxnez.
  • scotta
  • Platinum Member
  • Platinum Member
13 Feb 2025 19:59 #321473 by scotta
Im confused --
Bad payload = 0
any suggestions
thanks
Les
For the RT1052 use the remora-eth-3.0 component that is included in that repo.
Remora-RT1052-cpp/LinuxCNC/components/Remora-eth at main · scottalford75/Remora-RT1052-cpp · GitHub
  • scotta
  • Platinum Member
  • Platinum Member
13 Feb 2025 20:06 #321474 by scotta
File Size:4 KB
File Size:3 KB
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
8403
The error gives a hint - motmod: already exists
Looks like you are loading it twice in your hal file. Try removing the 2nd line. From above EMCMOT=motmodloadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD #num_joints=[KINS]JOINTS[TRAJ]SPINDLES
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
14 Feb 2025 01:35 #321500 by cakeslob
Im confused --
Hey, can you explain the process that lead you to download the firmware from one repo, but install the component from another? I am trying to identify what is causing people to continue to make this error
remora-docs.readthedocs.io/en/latest/har...Ethernet/rt1052.html
14 Feb 2025 05:37 - 14 Feb 2025 06:25 #321507 by beauxnez
has anyone made qtplasmac work with a NVEM card?
i modified the .hal file with
[code]Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
Found file(lib): /usr/share/linuxcnc/hallib/qtplasmac_comp.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: qtvcp
No section: 'SHUTDOWN_OPTIONS'
Adding section SHUTDOWN_OPTIONS
Running HAL shutdown script
task: 809 cycles, min=0.000007, max=0.010275, avg=0.009722, 0 latency excursions (> 10x expected cycle time of 0.010000s)
[QTvcp.QTVCP.QT_MAKEGUI][[31mERROR[0m]  Trouble looking for handlers in 'qtplasmac_handler': (qt_makegui.py:330)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 308, in _load_handlers
    objlist = h(halcomp, widgets, self.PATHS)  # this sets the handler class signature
  File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 6000, in get_handlers
    return [HandlerClass(halcomp, widgets, paths)]
  File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__
    float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60
TypeError: float() argument must be a string or a real number, not 'NoneType'
[QTvcp][[41mCRITICAL[0m]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.9.0~pre1+git20230208.f1270d6ed7
  File "/usr/bin/qtvcp", line 508, in <module>
    _qtvcp = QTVCP()
  File "/usr/bin/qtvcp", line 251, in __init__
    window.load_extension(opts.usermod)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 265, in load_extension
    methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])
 (qtvcp:464)
15446
15483
[/code]
Last edit: 14 Feb 2025 06:25 by beauxnez.
14 Feb 2025 08:13 - 14 Feb 2025 08:14 #321518 by LeslieTroyer
of the repositories that looked "hopeful"
Remora-main, and Remora-RT2052-cpp-Main had remora-the-3.0.c
both the same -- neither worked (forgot to incclude that)
and the one listed which also didn't work -- (same error)
I think maybe the 3.0 one I worried was specifically related to the EC500 (all the remora-??? directories under LinuxCNC appear from filenames to be ec500 based
i did hook up a LA1010 to the rs232 port and saw lots of data being transmitted but not much was readable - i then connected the screen that come with the NVEM to the serial port - and now my device its totally unresponsive on the serial port and ethernet port ...
Last edit: 14 Feb 2025 08:14 by LeslieTroyer.
14 Feb 2025 15:43 #321556 by cakeslob
If your board has the RT1052, refer to the page I linked to, and only install the components/firmware/configurations referred to in the documents. The linuxcnc .hal file configuration doesnt matter if its EC500 or NVEM. The config.txt is important to match with the board.
Time to create page: 0.238 seconds
