Homemade, cheap, plasma CNC
4 years 10 months ago #230061 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Thanks Rod,
Did have some luck tonight getting spotting to work.
I followed some instructions from arclightdynamics on youtube, they did a clip called 'plasma center punch training video'. this made a little bit of sense to me for some reason, then coupled with your advice I'm getting somewhere now. Currently in the GUI I have 1V and 2ms. this is working and not punching through 1.2mm steel. I'll mess around with it some more tomorrow.
Philc54, Thank you. I had looked into this previously, however I wasn't at this level yet to fully appreciate how this would work. I am getting there and this will be my next hurdle. I do use it to some capacity using "mark edge' & 'set origin' to align my material if I can't be bothered to set it on the machine correctly or if it's a small bit for a quick cut. Hopefully soon I'll have this setup.
Cheers
4 years 10 months ago #230065 by RNJFAB
 spotting
4 years 10 months ago #230070 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
Looks perfect! Time to move on to the next challenge!
Just watch that the torch voltage does not flicker over the 1 V threshold  when its not cutting.
The following user(s) said Thank You: RNJFAB
4 years 10 months ago - 4 years 10 months ago #230427 by RNJFAB
Thanks Rod,
Next challenge is the torch mount properly, even with 10 'strong' magnets, it still breaks away too easily, and I don't have. micro switch on it yet to pause the machine when it does breakaway.
Also brains trust, I want to upgrade the 2 relay's I have to a set of 8. however I'm struggling to find a correct wiring diagram on getting it connected to the MESA board.
Pics to follow of current setup, new 8x relays, current wiring diagram. I need help on how to connect this all in properly, I'll also put up my attempt at connections.
Last edit: 4 years 10 months ago by RNJFAB.
4 years 10 months ago #230428 by rodw
Thanks Rod,
I found vicegrips solved this
4 years 10 months ago - 4 years 10 months ago #230435 by RNJFAB
Attachment not found
Current solution.
Time to create page: 0.381 seconds
