- Thank you received: 2100
That looks like your internat connection may have an issue.This is the error I got updating.
I am lucky, we got fibre to the premises before Malcom Turnbull stuffed it all.Probably the internet. Bloody NBN in AUSTRALIA is slower than when we had broadband. I’m lucky to get 15MBPS, but if it’s raining that will drop out. Max upload is 0.5MBPS. They know we are too far from the nearest node to get a reliable service, and they built a new node closer. But the “experts” say we can’t connect to the closer node. 4 year battle with telstra and the NBN.
will try when the rain stops.
I've only ever used auto volts since before Plasmac was invented.Thanks Rod,
I was thinking of doing the same, however I'm having issues if I have VOID A/DIVE on. This will from time to time cause the torch to crash, with it off I have had no problems. Also if I have AUTO VOLTS on it can be a bit hit and miss, sometimes a perfect cut, sometimes crash every 20mm or less. The torch just keeps diving.
Currently with the volts set for each material and a bit of tweaking, I have nice cuts for all the material I normally use.
